Problem with trailer lights
Old Apr 10, 2004 | 12:08 PM
Brett englund's Avatar
Heres the problem; when I use the turn signal, the hazards on the trailer start to go; the hazards dont work unless the headlights are on ect... ect... ect... Any one have any idea?
I have the round trailer plug, and the rectangular adapter. 4 wire setup
2000 F-150 4x4
Old Apr 10, 2004 | 04:11 PM
FordMasterTech's Avatar
Does this happen when u are not hooked to a trailer?
If so, then you have a short to power on your trailer wiring harness.
If it doesn't matter whether it is plugged to trailer or not,
Short to power through a switch or wiring..
Let me know more details
Old Apr 11, 2004 | 11:52 PM
lees99f150's Avatar
sounds like a bad ground connection on the trailer. check on the trailer where the black wire connects to the trailer frame. if it has no ground then one circuit will back feed through another causing weird problems
