Kam Fuse?
Old Apr 7, 2004 | 04:41 PM
ken kaiser's Avatar
Angry KAM Fuse? (Keep-Alive Memory)
"I have a 1996 F150 4x4 302 automatic transmission that will not go into gear. The ABS light blinks 16 times ( on the 16th time it stays on for an extra second and counts again to 16) and the book I have says to replace the KAM fuse. I cannot find this fuse in the wiring schematics. I did replace the ABS sensor/switch that goes on the front of the master cylinder, I had the ABS light blinking before I replaced this part. If I disconnect the negative battery cable and turn the ignition key on I am able to put the truck into nuetral reconnect the negative battery terminal and start the truck and put it into gear and drive it. As soon as I put the truck into Park the gearshift will not go back into gear even if the vehicle is still running. Proves to me that it is electrical. Can you help me!";
Old Apr 7, 2004 | 10:07 PM
STAN/SRMASTER's Avatar
CHECK FUSE 13 (INSIDE FUSE BOX)IF BLOWN, IT WILL CAUSE BOTH OF YOUR CONCERNS, IT IS AT THE VERY TOP OF FUSE PANEL.
Old Apr 9, 2004 | 02:04 PM
ken kaiser's Avatar
Thumbs up Many Thanks!
Thanks for your timely reply, that fuse 13 was the problem with my truck. Now the "Check Engine" light is on constantly, I will troubleshoot this best of my ability but if you have any suggestions please feel free to throw them at me.
