power seat question
power seat question
If I have power seats and the motor quit working. how would I move the seat back? Also, how would I test the motor to see if it works. IS there a hot wire I can hook to to check it?
Check the fuse in the Power Distribution Box in the engine compartment:
Fuse 112 it’s a 30 amp fuse.
That might be open. Other then that I don’t think there is a way to move the seat manually, there might be, but I don’t think so. To check the motor you would have unplug the connector and know which wires are for the motor and then you could check resistance to see if there is an open.
More then likely it’s a blown (open) fuse…
