Turn signal wiring problem
Old Feb 23, 2004 | 05:21 PM
wis-ford's Avatar
My turn signals don't work when I tilt my steering wheel down. Has anyone else had this problem? Is there an easy fix?
Old Feb 23, 2004 | 06:55 PM
STAN/SRMASTER's Avatar
Remove steering column trim covers,3 screws in bottom. It is likely the T/S connector where it plugs into the switch or wires pulling out of T/S connector.
Old Mar 1, 2004 | 12:24 PM
RickK1974's Avatar
I have exactly the same problem and will try the fix you suggested.
Thanks!
Rick
