elec on engine swap
Old Feb 10, 2004 | 06:04 PM
wtex's Avatar
Question elec on engine swap
we put a 2000 liightning engine in a 97 f-150, also put wiring harness from a 2000 f-150 in it also but it is missing a few wires for egr. can you help? won"t fire off.................
Old Feb 11, 2004 | 08:37 AM
SSCULLY's Avatar
You needed a L wiring harness, PCM, and I think even the GEM is different from your 97.
Add to this, the PCM and GEM for the L is looking for the PATS in the instrument cluster, you need to get around this as well. Only way I can think of it by replacing the instrument cluster with one from an L, and the PATS programming to match.
Never seen someone try to use a non L PCM with a L engine. ???
There are a few posts on L engine swaps, a member on the boards here did his, and helped ~8 others do the same. It lists in detail all the items that are needed for the swap.
Old Feb 11, 2004 | 09:11 PM
lightningsc's Avatar
2000 lightning engine into 97
wtex did the complete 2000 lightning engine into my 97 supercab, you will need a lot of parts give me a call at (843) 247-3700 or give me your number and i will call you i have free nights ans weekend on my mobile. gary
Old Feb 12, 2004 | 11:28 PM
TonyPTX's Avatar
You can bypass PATS by installing a resistor somewhere in the circuit. Don't ask, I just remember seeing this when I was looking at putting an aftermarket remote start into my pickup w/ PATS.
Tony
Old Feb 14, 2004 | 09:20 AM
SSCULLY's Avatar
Tony,
You are 100% correct. The Ford part number for this is :
1L3Z-19G365-AB. This is the ring that installs around the ign under the steering coulmn cover.
Only problem is, this programs like a new key.
I thought that the non-Ford remote starts you had to program the new key, most cut the teeth off if it, when putting it in the install. Maybe that is only some of the kits, maybe I am totally off my rocker
Steve
