Airbag light on solid for 5 second at startup only
Old Jan 31, 2004 | 09:34 AM
Highmilage97's Avatar
I recently noticed that the airbag light is on solid for about 5-6 seconds at startup only, then it disappears. No flashing.
Any ideas?
Old Jan 31, 2004 | 09:46 AM
Dr No's Avatar
I am pretty sure that is normal. It is called a bulb check. Are you worried because it does not flash seven times like General Motors
air bag. It does not work the same.
Not to worry.
Mike
