Removal of headlamp assly
JUST HAD TO REPLACE HEADLIGHTS ON MY 99 LAST MONTH. VERY SIMPLE JOB NO TOOLS REQUIRED. OPEN HOOD BEHIND EACH HEADLIGHT ASSEMBLY ARE TWO TABS. ABOUT 1-1/2" WIDE PULL THESE TABS STRAIGHT UP. THIS WILL RELEASE HEADLIGHT ASSEMBLY. YOU WILL THEN SIMPLY SLIDE HEADLIGHT ASSEMBLY OUT. MAY NEED TO WIGGLE ASSEMBLY TO KEEP IT COMING OUT. ON REAR OF HEADLIGHT UNSCREW LOCKING COLLAR REMOVE OLD BULB. REINSTALL NEW BULBS, I RECOMMEND SILVER STARS, SLIDE ASSEMBLY BACK IN PLACE AND PUSH DOWN LOCKING TABS. QUICK AND EASY.
Originally posted by FlaresideGuy
RockPick,
I tried your link and, if you are not registered at the site, the link doesn't work.
John
RockPick,
John
Those guys over at FTW are kind of **** about that... sorry, I tried to help... *shrugs*
RP
