PATS Key Problems
Old Jan 18, 2004 | 10:31 PM
messman24's Avatar
PATS Key Problems
I have been Tring to get my new Remote Start working this weekend a managed to make one of my keys set the Theift light off one key still starts the truck but the other does not I can get it reporgramed to start the truck any ideas.. 2002 screw
Old Jan 19, 2004 | 10:27 PM
S'CrewLoose's Avatar
I hate to say it but your name says it all...you are in a MESSMAN....If you only have one key that starts your truck you must bring it to the dealer to have them reprogrammed. Although, I can not understand how you De- programmed your key, maybe you can try and explain how you did that? Also tell us what kind of pats bypass you are using. I and plenty of other here have said...make sure you have at least 3 keys at all times programmed for your truck, if you lose one, program a third right away. You can pick up a key at your local Ace hardware for around $20.00 and program it yourself....its cheap insurance.
Old Jan 20, 2004 | 06:37 AM
messman24's Avatar
I managed to Get lucky on this on an got the key working again, this all happen while working on my remote start install, i had programmed my Pats Bypass Frist but somewhere in the mess of things i guess the Pats Bypass and one key got programmed together. so i was able to get the key back onec i hooked everything up without a problem. Man i am a Mess..
