Turn Signal Problems
Old Jan 4, 2004 | 08:26 PM
Player's Avatar
Ok not really sure if this is the right forum to post in but i'll leave it here for u guys to answer anyway. First i have a 98' extended cab flareside. Now the problem is that when i go to turn on the signal and push it totally into place it tends to make a faster clicking noise then what it usually does and the turn signal doesnt go on. This tends to happen mostly when i push it into the the position for the right turn signal but will happen sometimes when i go to turn on the left trun signal.
Heres a little twist... the only time that it doesnt work is when i go to push the lever all the way into position. When i only push it partially into position then it works like it is supposed to.
I may not have explained my problem enough so if u have any questions i am pretty sure i can answer them. Thanx in advance i am sure u guys will be able to locate the problem and come up with an answer.
