Driver side Pwr Window motor binding?
Old Dec 4, 2003 | 02:43 PM
ane182rf's Avatar
Have the 98 F150 with "one touch" down driver side window. I greased all the tracks inside but the window still won't come all the way down with one push of the button. I have to push it three times to get it all the way down. Seems to bind or gets slow when near the half-way mark going down, no binding going up though. Is this an issue with the window motor itself or has the linkage worn itself causing the problem?
Appreciate any advice on the matter.
Now have a sam adams on me , it's always a good decision...
Old Feb 28, 2004 | 02:31 PM
(o)here(o)'s Avatar
bump.
ive been having the same problem now for about a year. though, once in awhile it seems to work just fine. i think in my case the felt on the outer seal that touches the window is worn and is creating too much friction.
ill replace it and let you know. has anyone encountered this as well ? any other suggestions ?
Old Feb 28, 2004 | 05:05 PM
STAN/SRMASTER's Avatar
Try some silicon spray in the window run(felt window runs in).
Old Mar 3, 2004 | 11:49 AM
(o)here(o)'s Avatar
silicon spray works wonders for yet another application ! thanks, for the tip
