Gem
where exactly is the GEM located... because after reading thers forums searching for my problem.. ( windows dome lights and wipers do not work!!!) and most people said they checked there GEM and i have no clue where this would look like or be located in!!!
its a black box mounted to the back of your fuse box. under the dash. there is not much to check. you cant hardly see it. check for power at all the fuses for you concern. and under hood fuses to. good luck.
