Air Bag - Flashing Code 52
Could someone tell me what this is and how to correct it. I was checking fuses before this happened and probably pulled the wrong fuse out to check! I finally found the fuse to my trailer lights and repaired them but now have the airbag light on.
This is caused by the system sensing a voltage loss (removing the diagnostic fuse). It can't be reset by normal means without an expensive scan tool, but after it goes through 256 cycles (turning the key on and off), it will reset itself.
