Fuse or Relay gone bad.
Old Nov 5, 2003 | 10:58 PM
lifeguardjoe's Avatar
I was cutting some wire, and touched two of them together, and didn't disconnect the battery. Well now none of the lights work inside the truck (dome and glove box light)
I think I blew a fuse or a relay. Any ideas?
Old Nov 6, 2003 | 08:12 AM
flafonman's Avatar
Check the 15 Amp fuse in position 14, it is probably blown. If it isn't, you may have damaged the Interior Lamp Relay, or Battery Saver Relay. Better hope you didn't fry the GEM with the Central Timer Module.
What color(s) were the wires you cut? It sounds like they were Black/Lt.Blue.
Old Nov 6, 2003 | 05:24 PM
One was black and the other was green with a red/orange stripe. Its raining right now. I'll check it out when it stops.
Old Nov 7, 2003 | 07:52 AM
flafonman's Avatar
Light Green/Orange is also served by fuse 14 (15A). That set of wires serves the Engine Compartment Lamp, Glove Compartment, and Map Lights. It is monitored by the Battery Saver Relay, and has a lead off the Main Light Switch which controls the Dome Lamp.
Old Nov 7, 2003 | 04:37 PM
Still havn't had the chance to check it out. I will probably in 30 or so minutes.
If its blow it would be black looking I'm guessing?
If not, what else would it be?
Old Nov 7, 2003 | 05:12 PM
Johngs's Avatar
If you look at the fuse, it has a thin piece of metal that goes into the plastic. It should be solid.
If it is broken...the fuse is blown.
Old Nov 7, 2003 | 06:43 PM
Yup it sure is broken. I checked it right after I asked the question, but didn't have the time to post. Thanks everyone for all the help You guys rock
Old Nov 7, 2003 | 08:43 PM
Johngs's Avatar
Make sure you replace that fuse with the same amperage...
Old Nov 8, 2003 | 04:28 PM
I did, and everything works great.
BTW, what would be the fuse for the 12v socket(or cig lighter) be?
Old Nov 8, 2003 | 07:51 PM
Johngs's Avatar
In my manual its position 3, 25A fuse.
you can go to http://myford.fordvehicles.com and register there. You can get your owner's manual online, find incentives, buncha stuff. its free
