ABS lite & brake lite
I have a 1991 F150 Supercab with RABS I (rear anti-lock only).
I have two (I hope) unrelated problems.
1. My brake lite will not go off. I disconnected the plug at the master cylinder and it went off, but it still works when I engage the parking brake. By the way, I know the switch is closed, because I jumped the wires in the plug and the light came back on. I installed a new master cylinder, bled the brakes and I have a full firm pedal. It is full of fluid.
Does this mean the float mechanisim is faulty?? Or, is the proportioning valve faulty??
2. I have lost 1/2 of my RABS diagnostic connector. My ABS lite was on, so I checked the fuse - o.k.. I took the rear sensor out and it was closed - read 1400 ohms. I proceeded to look under the dash to run the "blinking light" test. Lo and behold, the diagnostic connector was disconnected. I found the black/orange wire and ran the test and got 4 blinks ( which according to my manual signals a broken circuit). I decided to reconnect the connector and see if I could get the light to go out.
BUT, I CANNOT FIND THE OTHER SIDE OF MY CONNECTOR. Could I have lost it?? Anyone know where the red wire side comes from or where it goes. Surely it did not just disappear.
Any info would be appreciated.
Thanks,
Chuck
Thanks,
Chuck
