Gem
From all the reading I have done it seems highly possible that is the fix for my problems. My wipers sometimes dont work right, and I have lots of trouble getting 4x4 to work.
Tom
Tom
hey tommyq did you replace your gem module? was it hard? im also having problems with my 4 wd sometimes it works but its definately an electrical problem i also think it may be the gem. any luck with yours? did that fix your problem?
No, I didnt replace it. I did however pull it out and clean all the contacts, and it helped mine. It is a toal pain to to get to though, to remove it the fuse box has to come out, and the only way I found to do that was to take off a lot of the lower dash.
Good luck,
Tom
Good luck,
Tom
