Amber parking lights.
Old Oct 25, 2003 | 01:30 PM
rnash's Avatar
Is there anyone that knows where i can tie into those front parking light. The one that come on at the first position on the light switch. Some place inside the engine compartment. Im installing side runner lights.
Thanks , Rick
Old Oct 26, 2003 | 01:04 AM
Pestco1's Avatar
If you are using a relay you might try getting a signal from behind the switch itself.
Old Oct 27, 2003 | 08:28 AM
SSCULLY's Avatar
About the easiest place I can think of under the hood is right behind the parking lamp itself.
Is this not a good place ?
Old Nov 5, 2003 | 08:46 PM
dasmaz81's Avatar
I would use a relay and connect right up to the wire behind the switch too. I did that for many of my many accessories.
