Fuse help
Old Oct 24, 2003 | 07:38 PM
HOSRACN's Avatar
Fuse help
Quick question, if my amp has 2 60A fuses in it for a total of 120A, would it do any good to have a 125A fuse on the power line near the battery?
If not, how would I put a 120A fuse there?
I just switched amps and had to bump it up from 80 to 120 and can't figure out how since they don't make 120A fuses.
Old Oct 25, 2003 | 12:30 AM
SSCULLY's Avatar
One small problem if you feed both lines with a single wire. That would need to be a ~ 1 AWG wire, akin to the size wire on a old 100A house service wire.
This stuff does not bend worth a damn, for routing the wire.
If you have 2 60 Amp fuses, the wire would be 2 x 6 AWG to handle the draw on the Amps that you have.
With that in mind, putting a 125 A fuse by the battery is only if there is a short in the harness, not so much for overload protection.
It would work fine for that need, so the 5 A larger fuse is fine.
Good Luck
