Passenger Side Power Window
Old Oct 15, 2003 | 08:49 AM
tffav's Avatar
Unhappy Passenger Side Power Window
My passenger side power window on my 1997 F150 Supercab stopped working. Neither the drivers side button nor the passenger side button seem to work. When I push either button, nothing happens...no movement or sound. The window is stuck in the up position, thank heavens. I can use a screwdriver but am afraid of doing more damage than good.
Any help would be appreciated. Thanks!
Old Oct 22, 2003 | 03:26 PM
Rockpick's Avatar
Moderator &
It sounds to me like it's probably the window motor. AKA: the actual device that pushes the window up or pulls it down. It won't open from the drivers' or the passenger side correct? (I'm just trying to rule out a switch).
Also, you might check to make sure that the connections on the motor itself are good.
You might try searching your local junkyards for one... Best of luck!
RP
