Negative cable replacement help needed
Old Sep 10, 2003 | 06:12 AM
SatanOfAZ's Avatar
I need to replace the entire negative cable in my '97 F150 S/Cab 4.6L and I cannot seem to find exactly where it grounds. I see it go under the exhaust manifold, but I can't see exactly where it bolts to the frame or block or whatever. If any has an diagrams or info that would help, please, do tell. My truck is stuck at AutoZone. It's 2:30am. Uhm, yeah. Thanks in advance!
Old Feb 27, 2004 | 09:28 AM
Mrford's Avatar
It grounds to the top of frame behind the right front wheel, take wheel off you will see it, then it goes from there to the engine, bottom bolt of the starter.
