Newer codes ?
Old Aug 7, 2003 | 07:39 PM
nascarscrew's Avatar
Newer codes ?
Hi all, I have done searches for the odo test codes, but most appear to reference codes for 2002 or before.
http://www.mustangworld.com/ourpics/News/99hec.htm
or don't reference a year
https://www.f150online.com/forums/sh...ight=test+mode
So my question is; are the codes the same for all 97-03 trucks ? The reason I'm asking is I saw codes that don't match either of the reference points above.
br 133 (fluctuating)
p"x" all showed a reading except pe1,5,6 (000)
ALTF --
Then these code readings didn't match up to above references
dtc 5284 (implies Oil Switch Failure)
Oil 000 (indicates acceptable reading ?)
CR - h (should be -L if it's running, right ?)
Can anyone shed some light on this ?
Thanks,
Nascarscrew
