Power window problem
My passenger's window will not go down anymore. For the last year or so it has been acting up. It would not go down if I pushed the witch down but it would work if I click it up and then down. I have tried both switches (on both doors) and neither work. I have not looked at the fuses yet but don't all of the power windows work of the same fuse? By the way, the driver's window works fine.
Thanks!
Thanks!
I can tell you that it is not the fuse/relay because they all run off of the same relay (a 30 amp relay under the hood). I would check the motor, thats the only thing i can think that it would be. Good luck.
Joe
Joe
