Door Ajar, Warning light
Old Jul 22, 2003 | 07:03 PM
Tool Fool's Avatar
Question Door Ajar, Warning light
Just curious if anyone has had a problem with their, "Door Ajar", warning light staying on? Mine doesn't do this all the time, but enough to be annoying Called the dealer on this & he suggested spraying WD 40 on the latch!? (thanks, Bubba!)
To those that would ask......... yes the doors are closed when this happens!
Any thoughts are appreciated.
Old Jul 22, 2003 | 07:51 PM
Rockpick's Avatar
Moderator &
Oddly enough, Bubba has a very valid point.
The sensor switch that is mounted in the door is a very common problem. You'll see this in several older (97ish) trucks and I've seen it mentioned on here numerous times.
I've heard that WD40 is, indeed, a quick and easy fix.
Find the sensor and drown it's sorrows...
RP
Old Jul 22, 2003 | 08:02 PM
grinomyte's Avatar
wd40 worked for me on my passenger door.
Old Jul 22, 2003 | 08:16 PM
Tool Fool's Avatar
Thanks, RP,
I was being sarcastic, but I guess I should try it before pre-judging "Bubba"!
Old Jul 22, 2003 | 09:26 PM
TexfordD's Avatar
Yep spray it right into the latch at the end of the door and open and close the door a few times....WWWAAALLAA
Old Jul 23, 2003 | 08:36 AM
flafonman's Avatar
The attached thread attests to the power of WD-40. Be glad Bubba suggested it first, some people have been hit for big bucks at the stealership.
WD-40
Old Jul 23, 2003 | 08:52 AM
01 XLT Sport's Avatar
Excellent advice...
Here is another, if you ever have a hard time at removing road tar or grime, some WD-40 on a rag will take it right off with easy...
Old Jul 23, 2003 | 05:40 PM
J-150's Avatar
Bubba did you a favour... but under the circumstance most would be suspicious.
Dont apologize for distrusting a dealer service manager.
Old Jul 23, 2003 | 08:33 PM
Rockpick's Avatar
Moderator &
I agree with J... no need to appologize. I will question anyone that doesn't seem to make total sense.
Hope that fix works for you toolfool...
RP
