Another bad door lock actuator
Old Jun 22, 2003 | 05:18 PM
54regcab's Avatar
Angry Another bad door lock actuator
Ok I have read a few threads on the bad door lock situation with these trucks.
So have any of you torn the door down to repalce the actuators ?
Has anybody found any "shortcuts" to replace the actuators ?
Has anybody tried contacting Ford about correcting this "manufacturers defect" , if so any luck ?
It seems like those of use with keyless entry/alarms have had more trouble than most, will Ford consider this something that would cause the problem if it was an aftermarket alarm system ?
My truck is 4 years old, I just paid it off last year and thought I was done putting $$$ into it
Only 38K miles on it !
Old Oct 22, 2003 | 03:00 PM
Silver Bullet 7's Avatar
My actuator seems to be dying. When I unlock the doors, it sometimes unlock slowly and sometimes it doesn't at all. I removed the door panel and it does the same thing. My question is, when the actuator dies, does it stops working completely or is it intermitent at first?
No TSB on All-Data. Where can I find a better built unit than the original one?
Thanks for your help,
Stephane
Old Oct 22, 2003 | 07:04 PM
54regcab's Avatar
Mine was intermittent before dying completely.
A new actuator was $50, paid a guy at the car stereo shop $20 to install it.
Old Oct 22, 2003 | 08:41 PM
edgex's Avatar
Mine just died!!!
I got the dealer (under warranty at 52k ) to replace both actuators and the relay. The parts are on order and should be fixed by next week. Mine did not die completely though, they just started to slowly go up and down. You would have to hit the button a few times so the lock would work its way up. After doing this they wouldn't work at all, if you gave it a few seconds to catch its breath the drivers side would work again for one cycle and then die and the passenger side?... Forget about it!
I don't know if the dealer will do anything for you or not, but it might be worth a try with only 38k. I had a connection at the dealer so that's how I got mine covered.
Good Luck!
Old Oct 26, 2003 | 01:31 PM
hmustang's Avatar
Angry
Mine on the passenger door quit about 2 months ago I don't think the dealer will help me out any way since my truck has 75,000+ miles on it and I'll will have had the truck 4 years in a couple of weeks. as long as I can unlock the door with the key I'll live with it.
