Wiring for power to foglights.....
Old May 4, 2003 | 06:15 PM
Viejo4X4's Avatar
Question Wiring for power to foglights.....
I've looked at everything I can think of .....OK, be kind.....and I haven't been abe to find any "auxilary" port or conection for wiring some additional off-road lights on my truck. Nothing fancy, just want to run a power lead off the fuse block to a switch to the lights. Seems like the older models were alot easier, with an accessory connection. Any ideas, thoughts, box scores?
Thanks...
Old May 6, 2003 | 12:22 PM
FordMasterTech's Avatar
The easiest thing that I can recommend is come off the solenoid on the firewall RH side with your power lead and an in-line fuse holder. Then mount your switch in the cab and use the switch for the ground. Connect all your wiring and you should be good to go!
Hope this helps!!
FordMasterTech
Old May 6, 2003 | 05:16 PM
Viejo4X4's Avatar
Thanks FMT......I'll give it a shot.
Old May 7, 2003 | 08:38 PM
Good Luck with your project, and let me know the outcome!!
If you need anymore help, just let me know.
FordMasterTech
