key-less entry question
You might want to look under your dash above the brake on/off switch, slightly to the right to see if you have a keyless entry module before footing the bills for the remotes. This was an option (factory).. If you spot it you will see a 5 digit code on the outside of the module.. Then you can get some key fobs.. But if your truck isn't equipped, you would probably be better off getting some aftermarket application to pursue the keyless feature, mainly because it is alot less expensive..
Good Luck!!
FordMasterTech
Good Luck!!
FordMasterTech
