Another FOB Question
Old Apr 22, 2003 | 09:42 PM
JD's Avatar
JD
From: Las Vegas, Nevada (originally from Kearny, New Jersey)
My main FOB died, the one I used for about 4 years now. I replaced the battery - does nothing. The spare works fine.
I searched and found the instructions to program FOBS - does anyone know if they have to be re-programmed once the battery is replaced or do you think the components just wore out? Don't want to mess with the programming and possibly sc@w up the good one if not needed...
Old Apr 22, 2003 | 10:26 PM
SSCULLY's Avatar
The code is stored in the truck, so if the battery needs replacing the FOB should still be programed on the truck ( code does not change due to a dead battery ).
Same concept as a garage door openner, as far as I understand it.
If I got it wrong, Danny or Jeff should be along to correct me.
Old Apr 22, 2003 | 10:42 PM
JD's Avatar
JD
That was pretty much my thought also, just started stabbing for something other than having to replace...
Old Apr 23, 2003 | 08:10 AM
buschman's Avatar
You absolutely do not have to reprogram the fob to the truck when replacing the battery. Sounds like your fob may have given up the ghost...
