radio dead
Old Mar 31, 2003 | 10:28 PM
brad428's Avatar
Question radio dead
I have a 2000 f-150 x-cab 4wd and i took the radio out
to install a fm modulated cd changer. After i got it hooked up
the radio want come back on.The clock still works but nothing
else.The radio worked fine before. Any help would be greatly appreciated.
Old Apr 1, 2003 | 11:40 AM
L in Detroit's Avatar
did ya try to get it back stock, take out the wireing for the modulator, it sounds like its getting power but not seeing the switched signal, might want to test the power connector and see if your getting all the 12v constant, switched 12v, ground and ill..
jim
Old Apr 1, 2003 | 07:43 PM
brad428's Avatar
Smile
I did that and found the problem thanks for the
help.I was afraid it was some kind of security
device causing the problem. THANKS
