Gauges
Old Mar 6, 2003 | 05:32 PM
ford_newbe's Avatar
Exclamation I need HELP
I just bought some new guages for my 2002 F150, and I can not seem to take off the dash part where it wraps around the headlight ***, dome light, air vent. Once i get that off i'm good to go. Can someone please help? I would greatly appreicate it.
Old Mar 10, 2003 | 02:21 AM
LeanNCut's Avatar
There are tabs inside the you need to push. Or you could do the 180 trick to remove the switch assembly. That didn't work so I just used long screwdriver to click-off the 3 tabs. They're located at 10, 14, and 1800 hrs. Good luck.
Old Mar 10, 2003 | 11:25 AM
SSCULLY's Avatar
Try this tread:
https://www.f150online.com/forums/sh...hreadid=109451
I think this is what you are asking about
Old Mar 11, 2003 | 10:57 PM
ford_newbe's Avatar
Thanks so much.....that helped a lot.
