Power window hangs up
Old Feb 14, 2003 | 01:19 PM
F150NKY's Avatar
Registered User
Talking Power window hangs up
I have a 97 F150 and i have started to have a problem with my drivers side window. It stops going down at about a 1/3 of the way down. Push on it some and it will go down. Then after about the half-way down mark it works fine.
It goes up fine.
Any ideas
Old Feb 20, 2003 | 09:45 PM
CurtO's Avatar
Unhappy Window hangs
I have a 98 extended cab and my passenger window does exactly what you describe. I've been guessing that the problem is a worn window seal at the base. You know how it has the fuzz on em when they are new. I think the fuzz wears off and sticks to the glass a bit at some point. I'm not sure about this, just a guess, but if thats it. It should be an easy fix.
CurtO
Old Feb 21, 2003 | 07:42 AM
AB's Avatar
AB
Hi,
You might want to search for *side window stick* to get more info.
The problem is your window rails are getting dirty.
I would try opening the window and applying some WD40 on its sides then open/close a couple of times.
Alex.
Old Feb 25, 2003 | 04:37 PM
svt2205's Avatar
My 98 did the same thing on the passenger door. The dealer fixed it, while under warrantee. I remember that there was a TSB for this, but don't know what the number is
Check with the local dealer and get a copy of the TSB, that should give you what you need to fix it or decide if you want them to do it
Hope this helps
