Mirror Signals
Old Feb 2, 2003 | 07:21 PM
fedwards's Avatar
Mirror Signals
I have an 03 Screw XLT FX4
Would anyone know if the wiring harness to change to the signal side mirrors would be hangin around in the door somewhere?
If it is whats easier or better to install Ford stock blinkers or any better aftermarket kinds.
Appreciate any advice
Fred
Old Feb 2, 2003 | 07:45 PM
SSCULLY's Avatar
Re: Mirror Signals
fedwards,
The wiring harness is in the door, in the same connector as the power mirrors.
If you are taling about the singal in the glamor cap, new mirror head time, as the harness is not in the mirror head.
If you are talking about the old style that replace the glass, muth mirrors, this is an easy swap ( muthco.com ).
Either way you can pull down the directions from Muth and see where the connector is at in the door panel,
Good luck selecting somethig for your truck.
Old Feb 2, 2003 | 10:10 PM
fedwards's Avatar
SScully
Re signal mirrors
Thanks man... checked out your advice and you're right..I'll let you know how I make out with the swap.
Thanks again!
