Interior Lights
Old Jan 30, 2003 | 04:15 PM
Bob Stout's Avatar
Interior Lights
I have a 1997 Lariat with the same problem I've read about with the stuck door switch . I've tried the WD-40 solution without much success and have decided to go ahead and replace the switch.
I was just wondering if I could get some help on what to look out for when removing the door panel to keep from screwing anything up.
Thanks,
Bob
Old Jan 31, 2003 | 12:14 AM
danny owens's Avatar
Hello Bob the 1st time will be a little tough, kinda hard to see the latch and you hand blocks your view. may need a mirror and flashlight. btw are you the same Bob Stout on the ACC message board? canoe or kayak?
Old Feb 1, 2003 | 08:30 AM
Bob Stout's Avatar
Thanks Danny,
Are you saying I can replace the switch without removing the door panel and latch as I've read before? If I have to remove the door panel are there any little tricks that I need to know about before I start prying on it?
No, I'm not into canoeing or kayaking. Must be another Bob Stout.
Thanks again,
Bob
Old Feb 1, 2003 | 08:47 AM
switch
door panel has to be removed, after a few screws of course and then i believe it lifts stright up (varies slightly from year to year or model to model and i cant remember them all)
