wiring harness
Old Jan 25, 2003 | 12:28 AM
suptupscrew's Avatar
wiring harness
hey guys, does any body know where the ignition wiring harness is located at.for a 2001 f-150, 5.4l,auto,4x4, is it under the dash by the service port, or in the kick panel? i am triying to tap into the starter wire to put a kill switch in. can any body help?
Old Jan 26, 2003 | 09:45 PM
ruger-dfw's Avatar
http://www.bulldogsecurity.com/wires...Wiring+Details
Old Jan 26, 2003 | 10:26 PM
SSCULLY's Avatar
suptupscrew,
I don't know if this was the part you were looking for or not.
( edit : got better pictures from CD then picture of paper manual )
The location of the ignition harness connector.:
https://www.f150online.com/galleries...2028-48908.jpg
The pinout for the connector block :
https://www.f150online.com/galleries...2028-48909.jpg
Let me know if this is what you were looking for or not, if not I'll try again.
Old Mar 27, 2005 | 11:35 AM
bamacpl's Avatar
I am trying to locate the Ignition Wiring harness....Does anyone know??? The above links are non-valid!
Thanks!
Derek
Old Mar 27, 2005 | 11:58 AM
chucks bp's Avatar
Under the dash in the location of the clutch rod that would go through the firewall if it were a standard there is a black 6 pin flat conector with a jumper installed in it. this conector would have gone on to the clutch position switch, It has a jumper installed in it for automatic trans. should be pin one and tow pin one has white wire with a pink stripe pin two is a dk blue with dark green stripe these two wires are conected together to alow starter to enguage. also I believe there is a 15 amp fuse in the central fuse box below the dash Fuse 21? that if removed will not alow starter to operate.
Old Mar 27, 2005 | 06:17 PM
bamacpl's Avatar
Thanks!!! Found it!
