mike, fuel injectors and fuel pump ?
Old Aug 19, 2002 | 09:15 AM
jgreen24's Avatar
hey mike, jason here, i spoke to you the other day about my before and after dyno's.
you recommended that i get bigger fuel injectors and fuel pump.
i believe you said go with 24lb inj and a 255 l/ph fuel pump, i may be wrong about the size of the fuel pump, but i do know that you said go with a larger one.
i have looke all over the place for these injectors and fuel pump but cannot find the specific ones made for our trucks. i believe you said you have them at performance, but when i pull up your website all it has on there is superchip ordering info..
exactly which ones do i need, because i am ready to order them asap..
will i also still need to reburn my superchip for the headers and now for the fuel injectors and fuel pump?
remember i have a 00 f150 w/5.4l ecu code act2..
Old Aug 19, 2002 | 10:40 AM
Peddler1000's Avatar
Jason,
This is not Mike, but I beleive you want the 185 liter/hr pump (comes as stock pump on Lightnings I think)and #24 injectors.
I think Mike will tell you that larger capacity pump WILL NOT require custom tuning while 24# injectors and headers WILL require custom tuning.
Additionally, you would have to order those items by calling him, I think. I'm sure Mike will clear up anything I did not have correct, but hope this helps.
