Micro tuner
Old Jul 15, 2002 | 05:45 PM
phill250sduk's Avatar
Question Micro tuner
Hi Mike ,
Thanks very much for the execllent service the tuner arrived last week , One qustion I downloaded the stock program no problem , it then said add tunning , pressed yes ,then offroad , pressed no , then read raise speed lim ,pressed yes ,
it then read installing tunning ,waited about two minutes it read disconnect tuner ! . Has it loaded standard programe or just changed a setting .
Thanks again for the service & help
Phill
Old Jul 15, 2002 | 10:03 PM
Former Sponsor
Hi Phill,
Great, glad to hear it!
It's loaded the CARB-certified +60 HP program for your Powerstroke diesel, from your description.
It will be obvious from the performance of the vehicle that you've picked up a lot of power when you drive it, the 60 hp gain and the additional 115 lbs./ft. of torque will make themselves known.
What happened when you said no to the Offroad program, the +60 HP program was uploaded at that point as that's the default when you say "NO' to the Offroad program, so that's what you're running on now.
It has also stored your stock factory program in the Micro Tuner, in case you ever want to go back to factory stock, which we advise doing when you take it in to a Ford dealership for service.
Have fun over there on your side of the pond terrorizing hot-rods with that heavy-breathing diesel!
