Nitrous and single program superchip
Old Feb 14, 2002 | 02:42 AM
krzcwby's Avatar
Question Nitrous and single program superchip
Here's the deal guys I have a 2000L with just a few basic mods. 90mm MAF upgrade, cold air intake, line mod valve, boost bypass, crankcase breather, and a few cosmetic mods. I just purchased a NX nitrous setup and plan on running it at a 75-100 shot setting, I'm going to install it with a W.O.T trigger switch. I already have a superchip with a single program. I need to know if I can get a program that will allow me to run this chip or do I need to purchase a flip chip? The way I see it is that since this is a wet system I would only need the chip to retard the timing at WOT or would this make the truck run bad when not on the bottle?
Old Feb 15, 2002 | 06:46 PM
Former Sponsor
You are going to have to use the 2-program Superchip Flip Chip for nitrous use, you always have to have a separate program for nitrous use. You cannot use a nitrous program for non-nitrous use, well, I should more accurately say you could but you wouldn't want to, as you'd be way down on power without the nitrous. And of course you wouldn't use your current program with nitrous, for obvious reasons.
We can take care of this for you, just give us a call our contact info is below.
By the way, I'm hoping that your existing Superchip has been programmed for that breather cap, as it leans out the motor significantly and must be compensated for. If we have already discussed that, forgive me, as with the use of screen names here we don't know who is who on the boards most of the time, so I just wanted to mention that in case you weren't aware of that!
Have fun with your Lightning!
