Computer code???
Old Nov 21, 2001 | 12:51 PM
97EB_X's Avatar
Computer code???
Can someone tell me how to get the computer code if the sticker on the passengers door hinge is missing part of the code?
Old Nov 21, 2001 | 07:24 PM
Former Sponsor
Hi 97,
Sure, just go to the computer itself, which is mounted inside the cabin just above the passenger's kick panel. It's a rectangular shaped aluminum box, it's thin, and you'll see that it is held to it's mounting bracket/plate by a small black plastic pressure clip. Simply remove that clip and then look in the back of the computer where that clip was covering up, and you should see another code sticker right there.
If not, let me know & we can give you some other places to look that will involve a little bit more work.
