programed entry code
Old Jun 30, 2020 | 08:38 AM
Gary Nelson's Avatar
How can I retrieve the factory keyless entery code on my 2004 Ford F150 without having to go to the dealer for the expensive dealer hookup on his computer? I purchased the truck used and it had no wallet card and no code shows on the PCM as the owners manual indicates.
Old Jun 30, 2020 | 10:51 AM
Pull out the back seat (upper portion), remove cover on backwall and on the driver's side you should be able to see the body security module (square box). On it is the default or assigned security code on a label.
