another check engine light question
Old Feb 10, 2019 | 05:52 PM
Herminator's Avatar
Angry another check engine light question
I decided to remove and clean the fuel injectors on my '93 F-150 (5.8 liter). All went well except that, during the successful test drive, my check engine light came on. I don't have any experience with code readers but can buy one if someone can tell me which type to get and what to do with it to clear the code. thanks!
Old Feb 10, 2019 | 07:47 PM
You don't need a code reader, all you need is a jumper wire and test light or analog voltmeter.
http://www.thorssell.net/hbook/eectest.html
You need to do key on engine off and key on engine running tests.
To clear codes, disconnect the battery for a few minutes.
Old Feb 10, 2019 | 08:42 PM
projectSHO89's Avatar
Don't even need the meter or test light. Use the CEL and and a paper clip and practice your counting skills. All you have to do is ground the STI plug (or connect it to the signal return pin, same thing) and then turn the key to RUN without starting the engine for the KOEO test. You also have to shut the A/C to OFF.
To clear codes on a an EEC-IV, pull the jumper while the codes are being transmitted. No need to futz with the battery.
Just follow the directions and practice reading the flashes before you reset anything.
Old Feb 11, 2019 | 01:18 PM
Herminator's Avatar
Thanks to you both, I will post results. I have figured out part of project's instructions but what do CEL and EEC-IV mean?
Old Feb 11, 2019 | 01:34 PM
Herminator's Avatar
OK, found EEC but what is CEL? thanks!
Old Feb 11, 2019 | 02:10 PM
check engine light
Old Feb 13, 2019 | 05:19 PM
Herminator's Avatar
Thanks again for the help. It was throwing EGR codes which I cleared by disconnecting the jumper after recording all info. I assume it was due to the work I did. Maybe I should have disconnected the battery before R&R the injectors?
Old Feb 13, 2019 | 06:41 PM
Wait and see if it comes back.
