Rough Running Idle on 2006 F-150
My 2006 F-150 with an Edge Evo programmer on it started running rough all of a sudden. Sitting idle the whole truck will shake. When you try to accelerate you have to put the gas pedal all the way to the floor to get it to pick up speed and change gears. It through a few different codes after which I changed the VVT Solenoid Timing Valve, and both Cam Shaft sensors. It still is running rough. Please help.
