jimbo74 needs a tuner
Old Jun 27, 2018 | 06:13 AM
  #31
jimbo74's Avatar
5 Year Member
well, changed it to running 91.... the exhaust actually sounds throatier if that is possible.....
Old Jul 2, 2018 | 08:29 AM
  #32
jimbo74's Avatar
5 Year Member
ok, so I noticed that my speedometer is still off... its about 5 mph off @ 40 mph..... so if my speedometer says 40 mph, I am going 45 mph via gps. at this speed, my rpms are around 1450.
I am not savvy enough with the tuner, so how do I get this to work now? Also, I noticed I can firm up the grans shift points by percentage? it is currently @ 0% should I increase it?
Old Jul 2, 2018 | 09:38 AM
  #33
Change the tire revolutions per mile. You need to lower your current setting about 10% or so, then use trial and error. If you don't know your current setting, look up the revs per mile for your tire size, start there. If the speedo reads low (like yours does now), lower it, if it reads high, raise it.
I'd leave the trans parameters alone till you get the custom tunes, then discuss it with 5Star.
Old Jul 2, 2018 | 09:52 AM
  #34
jimbo74's Avatar
5 Year Member
Originally Posted by glc
Discuss these issues with 5Star.
I actually haven't had a chance to get the custom tunes done yet. This is all just using the stock canned tuning that the unit allows.
I still need to put my intake on, and do some other stuff, like have some time.... I work @ Tesla, and we are working like crazy pumping out cars
Old Jul 2, 2018 | 10:15 AM
  #35
Check my post again, I was editing it when you posted.
Old Jul 2, 2018 | 10:45 AM
  #36
Okay, I cranked your numbers into a gear ratio calculator - at 45 mph, 1450 rpm, in OD with the torque converter locked up, tire diameter calculates to 33.3". This is around 625 revs per mile. Start there, correct as necessary till the speedo reads about 1 or 2 mph high. (60 on GPS, 61 or 62 on speedo)
This also assumes that you have the correct gear ratio programmed, I used 4.56.
Old Jul 5, 2018 | 09:36 AM
  #37
jimbo74's Avatar
5 Year Member
sweet thanks. I do have 4.56 programmed in
Old Jul 15, 2018 | 09:48 AM
  #38
jimbo74's Avatar
5 Year Member
so, just programmed it, is the 2mph on the speedo over for 60mph only? or am I aiming for 2mph speedo vs gps at all speeds?
Old Jul 15, 2018 | 09:23 PM
  #39
It's going to vary - 2 mph at 60 is the best place to be.
Old Jul 16, 2018 | 12:26 AM
  #40
jimbo74's Avatar
5 Year Member
So, I put it in today. It is currently spot on at all mph under 50 mph. I didn't have a chance to go any faster today.
I am putting an intake in, and have had problems all day. Broke my upper radiator nipple too! Ugh, I have a fix idea though, hope it works.
Old Jul 16, 2018 | 09:19 AM
  #41
If it's spot on under 50, that's close enough.
Old Jul 16, 2018 | 09:25 AM
  #42
jimbo74's Avatar
5 Year Member
cool, sounds liek I am going to leave it then.......
if I get pulled over, I will jsut use the excuse that I was going the speed limit based on my speedometer the larger than stock tires must be @ fault
