Worthwhile chips or tunes to increase mileage
Old May 1, 2018 | 11:26 AM
scottfiscus's Avatar
I cant believe I only get 11.5 mpg. Even when driving like a grandpa....which I am lol
Old May 1, 2018 | 08:52 PM
MitchF150's Avatar
Well, without any idea what you are driving, that could be good mpg or not so much...
In general, I hear you can get a magnet and place it on the fuel line and that's supposed to increase mpg's... Or you can get this "fan" thing you put in the air intake and that's supposed to help too..
I'm not an actual grandpa, but old enough to be one!
Good luck!
Mitch
Old May 1, 2018 | 11:08 PM
2004 fx4 5.4 triton supercrew
Old May 1, 2018 | 11:22 PM
Roadie's Avatar
Is it jacked up with larger tires?
A tuner will improve the fuel mileage slightly depending on the tune. My Superchips did improve the mileage on my 2002 5.4.
Old May 2, 2018 | 12:03 AM
33s and no lift i dont think. i just bought it
Old May 2, 2018 | 12:29 AM
MitchF150's Avatar
So, we are getting warmer... How many miles? Ever had a plug change? Fuel filter change? Air cleaner change? How are you calculating the mpgs? Is this all hwy miles or just city or combo?
If it's got 33" tires, the speedo is likely off a tad.. So, the miles shown on the odo will be less than actual. So, even if you are using actual gallons and your odo miles, it's gonna be off a tad.
Mitch
Old May 3, 2018 | 12:49 PM
189k regularly serviced im told itsa mix of driving conditions
Old May 3, 2018 | 03:08 PM
Roadie's Avatar
Make sure the speedometer and odometer are correct. You can check it with a gps or time the truck between mile markers on the interstate. If it is off, a tuner can correct it.
I used to run stock size 265/70x17 P metric Michelins pumped up to 40 psig to improve the gas mileage. I checked it twice on trips to and from Homestead FL to Wilmington NC about 800 miles. It was 4 lane almost all the way and i set the cruise on 80 mph most of the way and it got 16.0 mpg. Since then I retired and don't drive it as much but I do like to drive out on the beach so I went to 285/70x17 tires and I'm sure that reduced my fuel mileage some.
Old Aug 9, 2019 | 08:29 PM
Phil in OKC's Avatar
Check with 5-star tune. I got a 5mpg increase in my mileage (15.7 to 20.5) on regular 87 gasoline with my 5-star tune.
Old Aug 12, 2019 | 08:41 AM
Fbird's Avatar
I got zero increase in MPG but much better transmission control and a correct speedo!!! with my 5-Star tune
4.56 gears and 35"s
