Can i do it myself
Got a 1999 f150 from a friend, had a 4.6 that had a blown head gasket, so got a 5.4 from a 2001 ford navigator with a kenne bell supercharger, what would i need to make this truck run? Where can i get a good laptop and if need programs to fire up truck? Engine is in the truck everything hooked up....thanks willy
the factory tune will run the swapped in motor, unless you’ve changed MAF and injectors
if you have then you’ll need a custom tune |
