edge evolution cs not matching real speed!!
Old May 2, 2016 | 06:56 PM
150welder's Avatar
Ok just recently added the cs edge programmer and went through and changed tire size and gear ratio but my programmer is reading around 10-12 mph slower at 45+ mph(ex. I will be going 75 by GPS but the programmer reads 64).... is there something I have missed here?
Old May 2, 2016 | 07:10 PM
Sounds as if your gears are inaccurate. As I recall, after you enter s value in gears or tired, you can go back and check your entry as it erases what has been entered. Could that be happening?
Old May 2, 2016 | 07:36 PM
150welder's Avatar
No I can go back in and it shows what the changes. I have 3.55 rear end and I have 38 in tires. And I have checked them both on quote a few occations. It has the stock tranny. Just not sure what I can do to fix the probably.
Old May 2, 2016 | 08:07 PM
Did you use their formula to calculate the tire entry?
Old May 2, 2016 | 08:53 PM
150welder's Avatar
Yes. They are military tires. Now will it hurt if I change the gear ratio up and see if it will bring it all into sync?
Old May 2, 2016 | 09:20 PM
329PD's Avatar
Can you adjust your tire revs per mile? My new MPT tunes were made for 275/70/18 but speedo was 4mph too slow. Adjusted for revs and I'm right on.
Old May 2, 2016 | 09:41 PM
You can adjust gears and/or tire sizes - doesn't matter which - just adjust till it's right.
