New Tuner help
Old May 12, 2013 | 12:55 PM
Good deal. At 6 years you got your money's worth. I change mine out before 4 years just so I don't get stranded. With these systems they can go with no warning.
Old May 12, 2013 | 04:52 PM
runnerbl's Avatar
Plugged the Edge back in today to make sure I had returned truck to stock. It read PCM w/o a problem. Programmed to level 2, started fine. Went back to programming and returned to stock. Truck started and drove fine. Now I will send the Edge to PHP and order my custom tunes. I have tried updating the Edge via the Fusion program and it says Unrecognized Device. I did some searching online and only thing I could find is someone said that if you get that then the programmer is still locked to the truck and truck must be returned to stock. Well, I have returned my truck to stock and still get that error. Have you seen anyone else have this issue when trying to update the Edge? The reason I ask is because if it is still locked and I send to PHP I will be charged $75 to unlock even though I know my truck is stock. Also, curious on what price is to convert to Gryphon if anyone knows. Hope to get in mail tomorrow.
Old May 12, 2013 | 11:34 PM
You need to contact PHP and discuss all this before sending anything anywhere.
