Programmer support for 4.6 2v?
Old Sep 10, 2012 | 05:22 PM
STXXXSTAR13's Avatar
as the title states, i picked up a tuner 2 summers ago for the 4.6 but it turned out it was software for for the 3v and i have the 2v. so after speaking to a rep from edge it wasnt going to work. wondering if theres anything out there for this particular setup yet.
i dont have much for mods, just a dynomax bullet muffler and the gotts mod for the 2010, if anything i wanted it primarily for the wheel and speedo compensation. going to be probably running the 275/70/18 cooper stt tek3's in the spring. wanted to try to get some power back from runnin the bigger tires. originally planned on jumping up to 4:10 or 4:56 gears instead of my 3:73's but i dont think i want to do that anymore. the tires weight 62 lbs as opposed to my toyo's that weigh 75. so it wont be as bad. but again, just want something for the speedo comp and to not be able to notice that im running heavier tires. not lookin to get 5.0 mustang type numbers out of this. any input would help.
i know diablosport was workin on something for the 4.6 a while ago but not sure if anything became of it. and from the website being the same at PHP as it was over a year ago it looks as though they are not supporting it yet either.
Old Sep 10, 2012 | 07:00 PM
dewalt17's Avatar
What model Edge do you currently have?
Old Sep 12, 2012 | 08:31 PM
i am using nothing at the moment. the edge evo ct that i had that did nothing for my truck after speaking with their reps was returned shortly after. so i currently dont have or have never used any type of programmer that supported the specs of my particular engine.
Old Sep 14, 2012 | 10:56 AM
DiabloMike's Avatar
Former Sponsor
can you get me the box code or calibration ID so I can see if we have support for it?
Old Sep 14, 2012 | 11:55 AM
Contact Mike@5star
Old Sep 16, 2012 | 12:30 PM
Tstarkey2489's Avatar
i hate to hijack your thread but im looking for a programmer for my 2000 4.2 and im having no luck. so please let me know what u ended up doing.
Old Sep 16, 2012 | 12:39 PM
Then why did you hijack it? Can't find the NEW THREAD button?
There's a bit of a difference between a 2010 4.6 2V and a 2000 4.2.........
SCT has programmers for a 2000 4.2.
Old Sep 16, 2012 | 05:51 PM
Originally Posted by diablomike
can you get me the box code or calibration id so i can see if we have support for it?
not sure if i know what you mean mike. I dont have anything at the moment. So if its a box code or cal id on the programmer you think i have i cant help you. Anything else i can provide you with please let me know. Thanks
Old Sep 17, 2012 | 03:43 AM
I believe he's talking about the codes on the bar code sticker on the PCM itself.
Old Sep 17, 2012 | 11:08 AM
DiabloMike's Avatar
Former Sponsor
correct, the PCM should have a 4 digit 'box code' on it, that will help
Old Sep 17, 2012 | 07:59 PM
Oh alright, let me get back and respond tomorrow when i have some more light and time. I will definately return and let you know what the numbers are. Thanks!
Old Sep 17, 2012 | 08:08 PM
Actually, just tried to look up where exactly the pcm is located on the 2010's and i cannot find anything on the web for that model year. Can anyone help? Thanks
Old Sep 18, 2012 | 12:08 PM
DiabloMike's Avatar
Former Sponsor
should be able to follow the harnesses to the PCM...
Old Sep 20, 2012 | 05:12 PM
Well ive looked underneath my dash on both driver and passenger side of my truck and i am unable to locate what im needing to locate. Unless its buried or somewhere else im definately not seeing it in plain view
Old Sep 20, 2012 | 08:20 PM
Try behind the passenger side kick panel.
