Gryphon (file missing update rquired)
Old Jun 1, 2012 | 02:12 PM
rodolan's Avatar
I bought a used gryphon and when I try to load it,it shows file missing update rquired RXDE5D2 hex anyone knows what wrong. Thanks in advance...
Old Jun 1, 2012 | 02:29 PM
If the monochrome gryphon you bought was sent to you with custom tunes still on it for the other truck you can do this to see what's on there....
How to Tell if You Have Custom Tunes Installed
In the main menu on the monochrome Gryphon, select [Diagnostics] -> [Tech Support] -> [Version Info]. (You can ignore the warning message that will come up). In the newer Gryphons, 04+, the "Calibration Version" should look like "0.x.xxxx" where the last 4 x's are (usually) the same as the Serial Number. If the Version number DOES begin with zero ("0"), you have custom tuned files. If the Version begins with one ("1") though, so it looks like "1.x.xxxx", then the unit has canned tunes, not custom.
Again - any calibration that looks like 0.x.xxxx is a CUSTOM build. All calibrations that begin with "1", i.e., 1.x.xxxx are CANNED calibrations in the newer model Gryphons.
But, any programmer with a Product Number that looks like --> Ex.xx.xx <-- is an older platform unit and the Power Programming Menu display cannot be changed. And, on those units, if the last 2 digits are "99" then it is always a custom file.
So, an older model Gryphon with a Product Number that looks like "Ex.xx.99" has custom tunes too.
So if this is the case then you'll need to update the programmer using Pegasus.....www.gopowerhungry.com click on the support tab to find Pegasus....
Old Jun 1, 2012 | 05:34 PM
rodolan's Avatar
My calibration# definitely starts with a 1, now what do I do? Thanks..
Old Jun 1, 2012 | 05:43 PM
Try using pegasus to update the programmer....
Link to download >>> http://www.gopowerhungry.com/_support.shtml#software
You'll need a pc.....doesnt work with mac
If that doesnt work contact PHP
Old Jun 2, 2012 | 09:09 PM
rodolan's Avatar
Done the download now it works like it should. Thanks again for the help....
