AFE getting into the tuning market! Scorcher Tuner for F150 EcoBoost
Old May 4, 2012 | 08:15 PM
AJUSA.com's Avatar
Former Sponsor
Chas of AJUSA.com here with another new product announcement for the 2011-2012 Ford F150 with 3.5l Ecoboost.
Check out this new AFE Scorcher Tuner for the ecoboost. This tuner is the first to incorporate mod specific settings to maximize the performance of intakes, exhaust systems, etc.
From AFE:
"aFe Power is proud to announce the release of a new SCORCHER Tuner for 2011-2012 Ford F-150 EcoBoost V6-3.5L (tt).
Finally a programmer for the EcoBoost that is integrated to work with aftermarket performance products. The new Scorcher from aFe Power utilizes a fully integrated tuning system that is matched to aFe Power performance intakes, exhaust and manifolds. These tunes are designed to provide maximum performance over the entire RPM range.
Producing up to 54hp and 68lbs. x ft. torque.
aFe has partnered with Superchips to develop the exclusive tunes to maximize all available power without sacrificing safety to the motor. This small hand-held unit contains multiple tunes per application that can be changed to match the driving condition (performance, mileage, towing, etc.). The easy to follow prompts make this product one of the easiest and fun ways to increase power and improve drivability."
Questions?:
Call: 800.877.1911
Email: Forums@ajusa.com
Old May 4, 2012 | 09:14 PM
aussiekeeper's Avatar
Is it guaranteed not to leave a "print"? Also, would like to see a dyno printout, where is the power?
Old May 4, 2012 | 10:52 PM
TOOLOUD's Avatar
Fast lane just came out with a plug n play module that supposedly doesn't leave a foot print.
Old May 7, 2012 | 01:22 PM
TOOLOUD's Avatar
Want more info - what does the boost run while under load ,egt's, does it have a display monitor to visually watch the boost/egt's ?
Old May 9, 2012 | 06:32 PM
AJUSA.com's Avatar
Former Sponsor
One the port is tapped, a print is left, no matter what tuner is on the market. It does come with the most recent version of the factory tune so you can always flash back to that if you need to
The Superchips unit, which this is based off of has a boost monitor, but does not read the EGT option.
Old May 9, 2012 | 07:55 PM
TOOLOUD's Avatar
What does the boost run while under load?
