SCT X3 error 1019
Old Apr 15, 2012 | 11:53 PM
Colorado01's Avatar
Question SCT X3 error 1019
Has anyone here ever had the 1019 "Unlock ECM Falied" error code? I just received my SCT X3 with custom tunes done by VMP Tuning, and whenever I try to program my pickup (2001 F150 5.4) it sits there trying to unlock the ECM for probably 20-25 minutes and then it comes up with this error code. What are some possible causes for this error code?
Thanks for your time.
Old Apr 16, 2012 | 06:17 AM
rufas's Avatar
I have had that when I turn the key to acc rather than on.
Old Apr 16, 2012 | 07:15 AM
MGDfan's Avatar
Rufus indicated one.
Here are some others;
http://www.allfordmustangs.com/forum...gnize-ecm.html
http://www.svtperformance.com/forums...ning-help.html
http://www.moddedmustangs.com/forums...ease-help.html
... there are many, many more (Google/Search criteria = the exact error message)
If it's not something simple like key position, you'll need to contact VMP and/or SCT.
Good luck.
Old May 7, 2012 | 06:39 PM
TestPoint's Avatar
My "Unlock ECM Failed" is apparently caused by the PCM making the determination that theft is occurring and setting a P1260 - 'Theft Detected - Vehicle Immobilized' code. At that time the SCT X3 responded with "SCT error 1019 - Unlock ECM Failed".
I have found lots of discussion on this subject but no solution short of towing the vehicle to the Ford dealer to have the PCM reflashed.
I found some comments on 'disconnecting battery' and 'touching ground cable to positive post of the battery' but that seems a little simple for what Ford considered a very sophisticated security system.
What was the solution to the OP's original problem or any other input to the PATS problem?
