gryphon wont turn on...
Old Nov 12, 2011 | 09:46 PM
TPAYNE's Avatar
ok so i just got a gryphon for my 07 f150 today but when i went to install it the screen would not turn on. i followed all the directions exactly as it was printed in the manual and also used a thread from this forum. does anyone have any input? it would be greatly appreciated, thanks.
Old Nov 12, 2011 | 10:11 PM
sam1947's Avatar
Does your cigarette lighter work ? The OBD II connector and the lighter are on the same fuse...check the fuse.
Old Nov 13, 2011 | 12:14 AM
damiansalmond's Avatar
x2 had the same problem
Old Nov 13, 2011 | 12:39 AM
TPAYNE's Avatar
Good call, forgot about that. Pretty sure that's the problem now. Which fuse is for the OBDII/cigarette lighter though? Not too familiar with all that..
Old Nov 13, 2011 | 01:16 AM
ak_cowboy's Avatar
It's listed in your owners manual. I can't think of it off hand
Old Nov 13, 2011 | 11:44 PM
TPAYNE's Avatar
no worries, i ended up finding it in the manual. much easier of a fix than i expected, such a relief. but now im getting an error code that reads f1 on the gryphon screen when i try to program a tune. pretty sure i just need to return it back to stock since i got it used so im going to try that out when i get the usb cable in.
Old Nov 14, 2011 | 08:38 AM
Not sure what you are saying, but if it has the stock tune from another truck in it, it has to return that other truck to stock or be cleared by PHP and reset.
Old Nov 14, 2011 | 11:06 AM
The error code 0xF1 can sometimes appear during programming. Try this:
1. Leave the ignition key in the ON position.
2. Disconnect the Gryphon at the OBDII port.
3. Plug the Gryphon back into the OBDII port.
4. After getting to the main screen, wait 15 seconds for needed parameters to be loaded.
If you still cannot program the PCM successfully, contact PHP for assistance.
Old Nov 14, 2011 | 04:06 PM
TPAYNE's Avatar
Thanks for the tip, already tried it though and no luck. Just going to call php later when i get off work and work it out through them.
Old Nov 14, 2011 | 04:09 PM
TPAYNE's Avatar
yeah i didnt word that too well, my bad.. what i was trying to say was that when i went to choose a tune to set my truck to the options were all custom tunes besides the #2 setting which was an 87 tow, so i tried to use this but after a minute of loading the oxf1 error message appeared. just need to figure out how to download pegasus now since i have a mac..
