Stumped by Excal II
Stumped by Excal II
Recently got my original Dyno tune emailed to me. The one in my Ecal II went corrupt and messed things up. With the new tune installed I played around with timing, A/F, and shift points. Had great power and acceleration. I am at +2 on global timing and A/F. Then noticed by GPS that my speed was off by 4 MPH. speedo read 80 and the actual by GPS was 76. I adjusted the tire size from 645 rev per mile to 660 and got it dead on. The problem I am having is that with that corrected if feels like the bottum fell out of it and the sound of the exhaust changed from rappy and crisp to a blaw drone tone. Anyone have any Ideas? I could sure use some help.
Is the Xcal2 capable of reading vehicle speed? If so, adjust it till the GPS agrees with the device, NOT the speedometer. Ford speedometers read a bit high by design.
Your tune may again be corrupt.
Talked with tarajerame and he thinks it maybe because the xcal was hot and it was hot outside as well. I brought the tuner in the house and let it cool down over night. This morning I reprogramed the truck and let it warm up at idle to do initial adjustments and let the IAC adjust. I will take it for a spin in a bit to see if that was the problem.
